Pickup Talk about Isuzu Pickup related topics here...
posi differential
Old Dec 25, 2008 | 03:31 PM
3SPEED's Avatar
hey all , I have a 94 pickup with a 10 bolt removable carrier rear end and I want put a posi in it. I have yet to find a co that makes one for it. Anyone know of one? Or what other removeable carrier rear ends Isuzu made that will fit in my rear axle. I was told some rodeo rear ends were interchangeable and some even came with a posi. Any help would be great. Thanks
Old Dec 29, 2008 | 01:20 PM
DJ_Rob_E's Avatar
3 speed what engine do you have??? are you sure it''s a 10 bolt???? the number of bolts is actually how many bolts are in the ring gear not how many are holding the drop out 3rd member in..... get back to me and i can tell you from here where to look and what your options for picking up an LSD rear end are going to be......
Old Dec 30, 2008 | 10:31 AM
3SPEED's Avatar
It has a 2.3l carb. There is suppose to be an id tag on the axle somewhere but I have yet to find it. How do you id the axle with out the tag or opening it up.
3speed
Old Dec 30, 2008 | 10:43 AM
DJ_Rob_E's Avatar
from what i''ve seen the I.D. tags are usually gone..... now that being said there is a MUCH easier way to find out if ANY Isuzu had the LSD rear end.... when you pop the hood there is an "options tag" from what i''ve seen it''s always on the drivers side pretty close to the brake booster look for the code "G80" to be stamped into it..... that "G80" code is the factory options identifier for the LSD rear end..... now then you''ll need to find either a trooper or a pickup with a 2.3 gas engine like yours and look for the tag under the hood..... yank the rear end and it should be plug n'' play [img]smileys/smiley2.gif[/img] just make sure that it''s not a pickup before the 88 year model as those were actually the P''up and anything 88 on was a pickup....... hope this helps
alajones
Feb 1, 2014 08:20 PM
renhouli
Jun 13, 2011 07:23 AM
nlandis
Jun 1, 2009 02:17 AM
sunnboy
Nov 26, 2007 06:10 PM
rick-I290
Oct 6, 2007 07:44 AM
