Go Back   Isuzu Forums - Isuzu Enthusiasts Forum > Past Models > Rodeo
Sign in using an external account
Register Forgot Password?
Connect with Facebook
Search
Reply
Thread Tools Search this Thread Display Modes
Old 11-07-2007, 10:13 PM
TCool TCool is offline
I have a 99 Rodeo, about 132,000 miles on it. The problem(i think its a problem) is that when I start from a stop and when I come to a stop there is a very slight jerk, I'm assuming this is coming from the transmission but not sure. Also it seems to shift a little hard from 2nd to 3rd, but nothing horrible. This stuff is so small that you can really only notice it if your are the one driving, but I'm worried that its a sign that I'm going to have troubles in the future. Does anyone know what the problem might be? Is this something that could be fixed by having the tranny fluid changed? I just bought this thing about a month ago, I'm really hoping I don't have any huge problems with it, anything you guys can tell me should help. Btw, the tranny was apparently replaced in 2005.
Old 11-14-2007, 03:11 PM
deben2859 deben2859 is offline
Common Problem with the Rodeo's (The thump when stopping/starting).
The clunk heard, on many 2nd generation Rodeo's, is due to wearing of
the grease in the driveshaft slip yoke. To correct this, the driveshaft
must be removed and regreased. I just live with it as I have heard of others re-greasing and it happens again.</span>
Old 11-14-2007, 10:58 PM
Well, if its not going to cause any major issues then I'll just live with it too. Its not that big of a deal.
Old 11-17-2007, 09:58 PM
Gizmo42 Gizmo42 is offline
Could possibly be the range sensor is dirty. HERE is a post on how to find and clean it. If it gets dirty enough the dash lights wont match what position the lever is actually in.
If you do get a fluid change just have it drained and filled or have the pans dropped, filter cleaned/replaced, then refilled. It will only replace part of the fluid at a time. Do not get a flush. That will knock loose all kinds of junk that will plug up the tiny ports in the trans and kill it.
Edited by: Gizmo42
__________________
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3\" Lift - Rancho 9000x
Rear no-slip locker
There is a very fine line between \"hobby\" and \"mental illness.\" Dave
Old 11-16-2008, 11:14 PM
fito1971 fito1971 is offline
I got this thump between 2 and 3rd gear.
I was so worried because I was 300 miles from home.
This happened a week after the trans fluid was service by jiffyLube.
After I got back in town I went to my mechanic and he added Lucas additive and found that it was a quarter of oil low.
This fixed my problem. This rodeo is a 99 and has 198.155 miles.
What I learn is not takemy rodeo to these quick lube places. They usually do not know about these tranys.
Or if you take it to those places you have to tell them how to do it.
Reply
Tags
1999, 2000, forum, hard, isuzu, knock, location, problems, range, removal, rodeo, sensor, shifting, switch, transmission
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Our Sponsors
Isuzu Performance Parts
Custom Hoop Steps
Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
