I just had this same problem FIXED after about 9 months of procrastination. My 2000 Trooper would never start the first time I turned it over, almost always started on the 2nd try. I took it to a small repair shop that actually spent some time trying to replicate and troubleshoot the problem (DON"T GO TO THE DEALER!!!). The culprit was that some fuel injectors were leaking slightly after the engine was turned off. That leaking was enough to flood the cylinder, preventing the initial re-start. A re-furbishment of the injectors solved the problem, to the tune of about $500 labor cost. My trooper has about 85k miles.
