No spark problem need help asap
Old 02-27-2012, 02:29 AM
cloudconnected85's Avatar
Default No spark problem need help asap
98 passport, 3.2 v6 4x4.
The engine is running on 3 cylinders, the three on the drivers side have no spark.
All cylinders have fuel.
Have swapped coils from side to side with no change, so its not a coil or plug problem. All six plugs and coils fire on cylinders 1,3, and 5.
The hot wire to the coil has power, just not to the signal.
The only cel i'm getting is p0121 for throttle position sensor, I'm thinking this is totaly unrelated besides the fact of a bad ecu.
All help is greatly appreciated.
Old 03-05-2012, 05:35 PM
Have spark now, all six cylinders have fuel and spark, but is still only running off the passenger side cylinders.
Some one please help me.
Still have p0121 after checking the wires and replacing the tps.
Old 03-07-2012, 03:56 PM
panther.stealth's Avatar
try replacing the tps anyway. a real bad one can do that. and i dont remember if these have an ICM but i might look into that.
Old 03-08-2012, 02:24 AM
I did replace the tips. But i noticed the intake manifold was missing a bolt think
It might have blown the gasket since it is on the same side the problem is. Got a head gasket kit and plan on checking and restoring the top end.
Old 03-09-2012, 10:35 AM
ahhh damn. good luck man. let us know how it goes. btw, is your name the song from the band In Flames?
Old 03-22-2012, 03:18 AM
lol officially hate this car. could not get the exhaust manifolds off, seems to be welded and can't get a breaker bar into position. But the intake manifold had a pool of oil inside it. Going to run a compression test to try and verify any blown gasket before i take it to a shop. Also am planning on checking wiring and timing. The insides of the heads show signs of the previous owners never changing the oil. FML
And yes from the band In Flames, great band.
Old 04-03-2012, 12:37 PM
smithwatson's Avatar
Spark plugs in vehicles are always play important role but at times it fails
Old 04-03-2012, 08:48 PM
Found the cause. It was a sheared pin on the exhaust cam. This caused the cam to rotate inside the gear out of time. Now just have to get gear off and fix the pin, but did finally get it to run on all 6.
Old 04-04-2012, 09:26 PM
Fixed... Put a new exhaust cam in it and it is running great.
TheDuckMan
01-01-2014 07:51 PM
chasidy
11-25-2010 08:51 PM
mudvaynedude122
09-21-2010 10:11 PM
89troop1
04-12-2009 07:52 PM
mmarlow
Pickup
02-12-2009 12:21 PM
Quick Reply: No spark problem need help asap
