1996 Rodeo High Idle After Warmup
Old 05-21-2010, 12:07 PM
alphatabs's Avatar
Default 1996 Rodeo High Idle After Warmup
Hi!
I have a 1996 rodeo, v6 automatic transmission. The truck idles fine until about 20-30 minutes of driving, then it begins to idle up high... over 2k rpm. I replaced the throttle position sensor and it ran fine for a couple of weeks, but its doing it again. Before I go out and buy another tps, iac, and egr I thought I would ask to see if this is a common occurrence and if anyone had an insight as to why. Is there a trick to solving this? It's driving me crazy, thanks!
Old 06-07-2010, 09:10 PM
rodeopassportenthusiast's Avatar
The only thing I can think of is the ECM reading the idle settings wrong. Or there is a good possibility you have an intake leak.
Old 07-03-2011, 08:02 AM
Quezzy's Avatar
Guys, dont trust a word rodeopassport says. He was spreading wrong info across the planet and creating a problem there.
Old 07-05-2011, 04:07 PM
Whatever you say.
OP, check for any leaks, especially vacuum.
wasim
12-02-2010 05:21 AM
willie15522
02-11-2008 08:40 AM
willie15522
02-09-2008 04:45 PM
tudman70
12-10-2007 09:17 PM
t429258
03-24-2006 02:43 PM
Quick Reply: 1996 Rodeo High Idle After Warmup
