2001 Rodeo idle problems
Old 06-13-2009, 06:44 AM
Schulzie's Avatar
Default 2001 Rodeo idle problems
Hey All!
We have a 2001 Rodeo, 3.2L, Auto, 4X4 with about 115k on the clock. Here in the last month, it has started to have a problem with idling. When started, it will intermittently rev from almost dead to 3000. It does not do this always, sometimes it is just a few times, or not to as high of a RPM. I have only seen this after start up, however my wife said it did it when she parked, and the engine was warm, it rapidly went from normal idle to 3000 RPM. She also has said it will do it when restarted after a trip, ie, warm engine. I have changed the fuel filter, air filter, PCV valve, looked for vacuum leaks and general security of engine components. It drives normally. I did the search and I will check the wiring to the power steering pump. Any help would be greatly appreciated. I'm much more familiar with my Jeep than the Rodeo, but the Rodeo sure is a good work horse for a nicer vehicle.
Old 06-15-2009, 06:36 AM
Schulzie's Avatar
Checked the wiring to the power steering pump, that's fine. Any suggestions?
Old 06-15-2009, 09:42 PM
Infiniti159's Avatar
Originally Posted by Schulzie
Hey All!
you replace many things you should buy a new car
Old 06-19-2009, 11:55 AM
OEDOR's Avatar
I would check the TPS (Throttle Position Sensor) Somewhere near the throttle. I have a 2.2L 4Cyl Rodeo.
I had an old trooper that did the rev up/down thing. That was a bad egr valve.
Old 07-27-2009, 06:04 AM
Schulzie's Avatar
Update-
Well, I think I may have fixed it. Of course it never really had the idle problem when I was trying to work on it, but it does idle lower, and the fan is quieter. Not sure how that is, but it is. I cleaned the throttle body up really good, but I had tried that before, just with Mass Air flow cleaner, not carb cleaner, so I don't think that was it. Then I removed the EGR valve and cleaned that out really good with carb cleaner. I got all kinds of crud out of that. Bolted everything back up, and it started right up, idle dropped immediately to less than it was before, and even the fan was quiet. Started it several times, then took it out for a good hard drive, and it ran great. Hopefully that was it. I'll post back it there is anything else that happens.
Thanks for ideas guys.
Old 11-13-2012, 11:28 PM
TonlRinla's Avatar
Banned
Piaget Limelight Paris-New York| The monuments of these two cities true architectural icons offer to us reasons of imagination and style. These two capitals of the world also post recognizable styles between all irresistibly urban and females. The towns of Paris and New York were for the creators and craftsmen of Piaget Limelight Paris-New York a captivating source of inspiration they illustrate the entire genius of the jeweler and watch maker in the Piaget Limelight Paris-New York Watch.Piaget took as a starting point two emblematic construction the city of love: the Eiffel Tower and the Large Wheel the place of the Harmony. Perfectly and fairy-like the Large Wheel is the pretext of amusing variations. Watches with parts and jewels moving with small diamond baskets suspended on the rotary table recall the genius of them.Inspiring by a sensual and extremely female seam Piaget Limelight Paris-New York dares to take the name "sexy one". Creations take again the laces of the corsets which are tied or are untied with delight. A voluptuous and a smart interpretation of these insane Parisian nights a collar of ruby and sapphires pink imitate the faces ribbons panerai luminor gmt replica watch which are given up to a non challenging face on a low neckline.In the same glamour spirit Piaget signs a fabulous watch cuff object emblematic and recurring in the history of the mark. Entirely paved diamonds the Piaget Limelight Paris-New York equips the wrist with light. It evokes a luxurious corset delicately laced by a diamond ribbon cuts square and also present them in a version ribbon of colored satin.Piaget chooses to retain two icons of the American dream: the Chrysler Building and the Statue of Freedom in New York.A spectacular ornament puts in scene a collar earrings whose design takes again with an exceptional control the illuminated roof of the building of style Art D��co to the purified lines and irresistibly graphics. The variation of this ornament in blue sapphire and diamond pimples boldly underlines the point of the mystical skyscraper and shines of glare like lights coloring a night sky. Reason for pendent or face earrings of watch the graphics of the seven points of the diadem of the Statue of Freedom symbolize the seven oceans. Latter inaugurated in 1886 and offered by France for the birthday of the independence of the United States was carried out by Bartholdi in collaboration with Gustave Eiffel for his metal frame. Entirely paved diamonds vostok europe watches the box of the Piaget Limelight Paris-New York makes the lights of the invaluable stones at the enviable rhythm of this city which never sleeps.Piaget chooses to take as a starting point the reef knots and the ribbons to confer a pace very to them. Black lines and diamonds are here with the honor. These creations are declining the colors and are translated into black and white of one evening new yorkiest tandems that charming reef knots decorate watches and jewels with a discrete elegance.Black tourmaline always but also black spinal cut in pearls so devotement can be shown faceted that they sparkle like stars on this long saltier a collar dances freely around the hand retained by a great bow tie of diamonds itinerant of thousand fires.Piaget Limelight Paris-New York Pictures
karrie01
01-30-2018 02:20 PM
wasim
12-02-2010 05:21 AM
wornout4wd
11-29-2010 08:42 AM
fodder33
06-30-2009 04:27 PM
hudsonhawk
03-09-2008 12:58 PM
Quick Reply: 2001 Rodeo idle problems
