Backup light switch location 04 rodeo
Old 06-27-2013, 01:39 PM
Jwms's Avatar
Default Backup light switch location 04 rodeo
Its wet out! Anyone know where the backup light switch is in a 2004 rodeo 4x4 automatic tranny?
Old 07-06-2013, 02:29 AM
Thomas Jacusy's Avatar
Hehehe.. You made a funny post here and I think that the light switch must be there when you will see at the backlight.
Old 07-22-2013, 08:33 PM
shadow_tek001's Avatar
Test
Old 07-22-2013, 08:34 PM
Sorry to hijack this thread, but does anyone know why I can't create a new thread? It just erases everything I type and then tells me my thread is too short!?!?!?
Edward
Old 07-22-2013, 08:36 PM
NM - it works in chrome.....
Edward
Old 12-30-2013, 10:07 AM
Old 11-11-2014, 02:58 AM
basit's Avatar
same problem there bro. i have also tried....
Old 11-12-2014, 09:41 AM
Jwms's Avatar
Mine was on the right hand side of the transmission (Aisan, not the GM). The part number is 8972071380. This switch is a multi function switch, not just the bu light. It is quite expensive. It is no longer available-obsolete. I did find it at Rockauto.com for about $200. The old one was frozen on the shaft and I tried everything in my arsenal to remove it to no avail. I finally gave up and took it to a transmission place and they got it off (for another $199!!-ouch!).
A side note...after I recieved the new switch and destroyed the old one trying to remove it, I plugged in the new switch to the wiring harness, set the switch in the "neutral" position so the vehicle would start and drive. This worked just fine until I made the decision to take it to a shop. The only thing I found that was disabled while the switch was in neutral permanantly was the cruise control...
shad2s
09-17-2013 11:19 AM
moorshk
02-23-2011 11:49 AM
malachi1616
11-15-2010 09:58 AM
lacy234
09-27-2010 05:11 PM
grone79
03-11-2008 06:36 PM
Quick Reply: Backup light switch location 04 rodeo
