First Generation Trooper technical Support
Old 03-03-2013, 12:07 PM
johnny5ive's Avatar
I've taken a handful of close-ups of an installed fuel injector for you to look at and compare to yours:
http://www.facebook.com/media/set/?s...6457980&type=1
  #12
Old 03-12-2013, 04:05 AM
JohnsonVance's Avatar
10-30 oil only, heavier weight oil can cause damage to the transmission.
  #13
Old 03-14-2013, 05:06 PM
scuddog's Avatar
10W30 in the manual tranny case it is.... I hope this helps my issue. Going into second or third in an upshift gives my stick shift a vibration and dull grinding sound. Rarely it goes into gear easily. I have to be forceful... not violent but very direct. 4th and 5th are a snap. Downshifting into second or third is almost not possible. It's as if something is not in synch. My fear is that the gears are ground down which is making this a mess. Wonder if transmission shops can overhaul something as old as this...
  #14
Old 03-29-2013, 10:33 AM
johnny5ive's Avatar
most of the shifting problems in these transmissions come from the clutch needing to be bled. It's a very difficult and time consuming task usually, but when fully bled out that usually solves the shifting problems.
  #15
Old 03-30-2013, 07:18 PM
Lunchbox21984's Avatar
or in my case were i have no hydraulic clutch, heavy weight oil might be needed
i got the old cable pedal type.
  #16
Old 07-26-2013, 08:31 PM
johnny5ive's Avatar
Ahh, you funny guy..
  #17
Old 08-04-2013, 11:05 PM
johnny5ive's Avatar
Bump for the only good thread on this forum.
  #18
Old 09-30-2013, 03:22 PM
johnny5ive's Avatar
This forum seems to be here for the sole purpose of generating advertising income... Seriously, nothing but ads EVERYWHERE... if you're looking for the REAL Trooper forum its right here:
http://w11.zetaboards.com/IsuzuTrooper/index/
  #19
Old 10-10-2013, 08:33 AM
johnny5ive's Avatar
Isuzu Trooper Meet this November
https://www.facebook.com/events/574033792640713/
  #20
Old 10-20-2013, 10:42 PM
johnny5ive's Avatar
Quick Reply: First Generation Trooper technical Support
