Hombre Talk about Isuzu Hombre related topics here...
isuzu hombre headlight assembly
Old 12-05-2011, 11:45 AM
ray massey's Avatar
Angry isuzu hombre headlight assembly
i was wondering if anyone knew where i could order a new headlight assembly for my hombre? I've been searching for months with no luck and it's really frustrating!!!!!
Old 12-16-2011, 10:29 PM
Hombre Drift's Avatar
I'm with you on that one. I've been looking for the past 2 years, and have my headlights ghetto rigged. The brackets are busted, and I had to use wood screws to hold the things together. The only place I found them was direct from the dealer, and they are selling them for $500 each. It's cheaper to do a complete S10 swap. As for me, I am looking at making my own set of headlights. Unless I try a Y2K Amigo sport setup. They look similar in shape, but I doubt the brackets mesh up.
Old 12-22-2011, 08:25 PM
vwgirl's Avatar
What about the red tabs that lock the headlamp in place? any source for those?
  #4
Old 12-23-2011, 10:38 AM
Default Red Tabs and headlights
Ok, for the tabs, you can try looking at the Chevy S10, or the GMC Sonoma assembly, since they are essentially the same truck. They have the same core support, and everything else. I think the 1998 -03 Sonoma would be your best bet.
Scavenged the junkyards for anything similar to the stock headlight setup. The most similar headlight was to a 2000 Honda Passport, and Rodeo, but the mounting points are way different. I'm sure you can make brackets and get them to work.
However, since I am in the same predicament, and in the research and fabrication mood, I think I'm just going to have to make my own headlights. I'll post pictures when I'm finished.
  #5
Old 12-23-2011, 12:58 PM
vwgirl's Avatar
they don't have the crazy NLA red tabs... no one seems to even know what I am talking about and GM denies their existence lol
Let me know if you figure something out!
  #6
Old 12-24-2011, 12:32 PM
Default Rd Tabs
Post pictures of them. I'm sure someone will be able t help you out. I'd check em out on my own, but my headlights are ghetto rigged in. The housings are toast, hence my building a new set from scratch.
  #7
Old 12-24-2011, 04:09 PM
vwgirl's Avatar
these guys
  #8
Old 12-25-2011, 02:03 PM
Yup, you are stuck with what you have. That clips over the adjustment screw. Nobody sells them. I have lens molds for the headlights. I'm building the backside base, for the lamp, but am thinking I'll pirate a set of lenses from a 1998 Sonoma, and pull the lens off of that, and retrofit the Hombre lens I made onto that, and also retrofit an HID projector as well, but am also thinking of LED. We'll see how it turns out.
  #9
Old 12-25-2011, 02:05 PM
Ooh, you can try finding a 1991-1997 Isuzu Trooper/Honda Passport. It is said those headlights will match up to the mounting points to the Hombre as well.
  #10
Old 01-11-2012, 11:40 AM
brad44's Avatar
There is a driver side headlight on ebay saw it today i am looking for a pasenger side.
Quick Reply: isuzu hombre headlight assembly
