fan motor not working
Old 01-11-2014, 02:07 PM
birdshot's Avatar
Default fan motor not working
2002 rodeo
My fan motor does not work on any setting, so i replaced it and still nothing. Fuses are good. How do identify a bad resistor and if its not that how do i remove the switch that controls the fan speed?
Thank you for thehelp!
Old 01-12-2014, 02:10 PM
Jacob Villalobos's Avatar
You might just need a now blower motor resistor. if you take the old fan and feed direct power and it spins fast then you didnt need a new motor. here is a like to help find the location of the resistor. http://www.justanswer.com/car/285eq-...-fuse-box.html
Old 01-13-2014, 12:36 PM
birdshot's Avatar
I did apply power directly to the old motor and it did not run. I have used a multimeter to check the resistor and everything is either open or short with no resistances. What are the odds I have a bad resistor and a bad motor at the same time? I was thinking it was maybe the switch that controlled the fan speed but need some direction in removing it. Thank you for the quick response jacob
Old 01-14-2014, 06:46 PM
The odds of the motor and resistor going out together is fairly high (like some people experience a alternator and battery at the same time). if you know the guys at the parts store see if you can look at one of their resistors and see if yours looks the same. some guys will even let you take it to the car to try it out first. when your switch is on high do you get full voltage out and then decrease as you reduce the speed?
Old 01-17-2014, 04:39 PM
birdshot's Avatar
I get something less than 1volt on any switch setting. Sometimes wiggling the switch will give me 12 volts across the fan motor wires.
Old 01-19-2014, 12:05 PM
it sounds like your switch has gone bad
Old 01-21-2014, 04:49 PM
birdshot's Avatar
Yup....back to the first post. I need some guidance on removing the switch. Thank you for checking back jacob:-)
tcyphers
04-04-2010 04:13 PM
JBayBay
02-17-2010 10:24 PM
IsuzuKid
08-08-2007 10:53 PM
mcputman917
06-16-2006 08:44 AM
Quick Reply: fan motor not working
