trouble setting timing - 2002 rodeo 2.2L
Old 09-11-2015, 03:12 PM
sharkmonkey's Avatar
Default trouble setting timing - 2002 rodeo 2.2L
Hello,
The previous owner stripped the heads off the bolts on the crank pulley so I am unable to take the pulley off to see the timing mark. Is there another way to check the timing? Will a timing light work if I rotate the crank?
Thanks,
-Mark
Old 09-13-2015, 02:36 PM
Hmmm, I think i am going to try another trick like putting a pencil down the #1 cylinder and rotating the crank until I find TDC.
Kwint
09-02-2012 12:43 PM
xpumpx
08-14-2011 01:20 PM
rodeo2002
12-10-2010 05:37 PM
sublime96
Axiom
10-13-2008 01:27 PM
Jasonrhsc
02-15-2006 01:10 PM
Quick Reply: trouble setting timing - 2002 rodeo 2.2L
