Run A.C., Water leaks in, where to look to fix?
the other day I actually used the A.C. for the first time for more than a half hour, ended up with water leaking onto the front passenger side floor. I know I've heard of it happening.. just wondering where I start to look for the problem.
I"m guessing it is condensation, and that maybe the drain line for it may be blocked,....... will I find it underneath the Rodeo, under the dash, passenger side inside , or under the hood by the firewall? just not really sure where the drain would be routed out.
Or is there something else I would need to check into by chance?
greenmaster
04-28-2011 08:45 AM
