overheats with new thermostat
Old 02-11-2016, 01:37 PM
amytre's Avatar
Default overheats with new thermostat
I have a 2003 rodeo with a 2.2l with a new head, head gasket, water pump. When it is running with the new thermostat it will run hot. So I used the old thermostat housing and remove the thermostat and it will run just fine, no overheating problem. My question is what is causing it to overheat when the thermostat is installed.
Old 07-06-2016, 12:35 PM
Oxwilder's Avatar
The thermostat can be put in upside-down, a common problem. It can also fit in backwards, a less common problem. Either of those can cause it to overheat. Also, if your particular thermostat is stuck closed, replace it with a new one.
mabelsplace
12-30-2007 12:41 AM
NickNack
01-15-2007 01:55 PM
NickNack
01-14-2007 11:08 PM
jscout
02-27-2006 02:02 PM
jeepster420
11-30-2005 09:21 PM
Quick Reply: overheats with new thermostat
