Fill ATF in Park or Neutral
I serviced the 2000 Rodeo ATF in Park but I think I have also read a post or two that says neutral. The Chilton Manual says Park.
I would be interested in the forum techs opinions & the reason(s) for it if you are willing to reply.
Also, does anyone know if the fluid has to be drained to change the accumulator piston cover?
TIA,
Pete
TIA,
Pete
I think the cover can be changed without draining, but I'm not positive. I've never done one. I dont even have an automatic. As far as I know checking the level should be done in neutral. I've also heard to manually shift through all the gears, then put in neutral to check. If nobody can give you a difinitive answer on the cover on here sign up on planetisuzoo.com and ask there. I know there are alot of ppl there that have changed the cover.
Smittysmymechanic
05-19-2011 04:00 PM
