Brake lights
Old 09-19-2007, 11:03 AM
IsuzuKid's Avatar
i have a 96 rodeo and my brake lights are always on and when i hit the brakes u cant tell the difference and my corner front lights come on when i hit the brakes.
Old 09-19-2007, 05:06 PM
Keefbikes's Avatar
[img]smileys/smiley11.gif[/img]Have you added a trailer harness to your Rodeo lately?
Old 09-19-2007, 05:26 PM
Trailer harness is usually a big cause of problems like that.
Also check your brake light bulbs. Make sure the connections are clean and the filiments arent broken. Sometimes one filiment can break and make contact with the other one to cause that problem.
Old 09-19-2007, 07:12 PM
IsuzuKid's Avatar
i've never had a trailer on it and what about the front lights and my brake lights are always on
Old 09-20-2007, 09:32 PM
Keefbikes's Avatar
There is a relay switch connected to your brake. To me it sounds like you have a fused relay,( ie. light switch), and you havea bad bulb or a bulb in backward causing the rest. Look in you repair manual and find the wiring diagram for the relay behined the peddle. If you dont have a manual, go down to checker or napa and buy one. It will always be handy with your Rodeo judging by the amount of threads you have started.[img]smileys/smiley2.gif[/img] Edited by: Keefbikes
Old 09-21-2007, 05:02 PM
IsuzuKid's Avatar
yea it was the wrong bulb in one of the tailights and now my lights work great and i own a manual but didn't need to use it thanks for the advice[img]smileys/smiley4.gif[/img]
TexasRodeo
10-25-2008 08:36 PM
tripjax
12-02-2007 10:44 AM
chabat
10-21-2007 04:53 PM
Trooperguy
08-28-2007 07:35 AM
houptee
01-03-2007 10:09 AM
Quick Reply: Brake lights
