98 rodeo battery light and brake light
Old 01-15-2006, 05:18 PM
derek44's Avatar
I have a 98 rodeo ls (manual). The battery lite and the brake light just came on and they stay on until after 2,000 rpm. When the engine drops under 2,000 rpm the lights come back on. The brake system, the battery, and the alternator have all been serviced within the last year. I've checked the fuses and they all appear fine as well. Anyone have any ideas of what the problem might be before I bring it in and sink more money into my vehicle.
thanks
Old 01-18-2006, 10:49 PM
Check the battery connections. Clean them or replace the clamps if they are bad. If that doesnt work then I would say the alternator is going out again.
http://forum.planetisuzoo.com/viewtopic.php?t=2921
Old 11-24-2006, 03:43 PM
floater's Avatar
I have a 1998 Rodeo. I had not driven it for 1 month, and after getting back in I noticed the red light for the battery/brake light, turned on as I accelerated, and it would turn off, at an idle or when I let off the throttle. I also noticed when i took a corner, the radio would lose it's reception, and then it pick up the reception after the corner. Last night, the dashboard lights and headlights all started dimming, and eventually went out. I pulled off the road, and as I cornered, all of the lights came back on. I later drove home, and the gauges all blinked off, and later came back on... Any help, appreciated.
Old 11-25-2006, 03:38 AM
Same answer as above but before alternator, check all the grounds between frame, body, and engine. Remove them and make sure they are clean, they might look ok but be corroded where they connect. Sounds like loose ground or battery cables but could be something loose in the alternator.
yhata
06-05-2010 03:23 PM
trfenix
Axiom
12-12-2009 05:05 PM
troopergirl
08-28-2008 10:12 AM
tide_belle
06-17-2007 01:12 PM
robdog
11-30-2006 12:54 AM
Quick Reply: 98 rodeo battery light and brake light
