Transmission Swap... Now New Problems
Old 03-21-2017, 09:26 PM
mr_carman007's Avatar
Default Transmission Swap... Now New Problems
Hello all, this is my first post, thank you in advance for the help!
I have a 2000 Isuzu Rodeo that began having transmission problems, it would slip off the line pretty bad and slip from 1st to 2nd gear. In order to repair I had my mechanic take the trans out of a 1998 Rodeo (ran and drove great, body was just beat to hell), he said everything was the exact same on both transmissions except 1 connector that was different. My mechanic pulled the trans from the 98 and put it in the 2000, now it is having shifting problems... its like it doesn't want to shift to different gears unless you manually shift it on the column.
I was hoping someone on here could share some knowledge! Thanks a lot guys.
Steve
Tim Baker
11-28-2015 04:03 PM
wasim
12-02-2010 05:21 AM
wornout4wd
11-29-2010 08:42 AM
pianobob
11-27-2009 06:29 PM
Quick Reply: Transmission Swap... Now New Problems
