Isuzu Pickup Question
Old 11-11-2008, 04:17 PM
DJ_Rob_E's Avatar
the o2 light is automatically every 90k miles flips on, to reset it you have to remove the instrument cluster out of the dash and move a screw on the back of the instrument cluster with the letters KSW to the other hole labeled the same, and then move it back to the original in another 90k....and again....and again.....
  #12
Old 11-12-2008, 11:20 AM
dbales12's Avatar
Originally Posted by D16z6
Im about to buy a 92 2.3l isuzu pickup with 94k miles and i was wondering what are some common problem on these truck? I read that head gasket and valve are common problem. Also the owner said the check engine light for o2 sensor is on and after he replaced it its still on.
What might be the problem?
Thank you.
the o2 sensor light won''t go off when you change it. you have to take the gauge cluster out and move one screw to another hole for it to go off. get a haynes manual on your truck and it''ll show you how to do it.
  #13
Old 11-12-2008, 11:25 AM
DJ_Rob_E's Avatar
yeah i hit the wrong button that was supposed to be a reply to someone else''s post, the wording now that i look at it again was a little wrong.... it should say the o2 light is set to automatically come on..... and obviously if you read the post i knew how to reset it and have done it before but i do appreciate your trying to help thanks!
  #14
Old 08-23-2013, 11:35 AM
drichers's Avatar
i can't find a replacement radiator for my 86 pup..(1.9 liter engine) any ideas?
  #15
Old 11-24-2013, 10:58 AM
alanauer's Avatar
No problems with mine.
deerejohn
12-14-2008 08:22 PM
spearbang
08-11-2008 04:59 PM
alanrush2004
05-28-2008 01:09 AM
1TLB
02-24-2008 12:16 PM
Harleygirl
06-15-2005 05:31 PM
Quick Reply: Isuzu Pickup Question
