Where can I get a a cylinder rebuild kit for a 1978-1980 50hp johnson outboard?
the lower cylinder has lost compression and there for will not crank. I need to know where to find a cylinder rebuild kit so I can get this motor running again. And this motor is a two stroke. We have took this motor to a perfessional mechanic and he said the only problem is that the lower cylinder is bad.Aney help would be most apericeated.
gasket kit
gasket kit
