Rodeo Windows don’t work from driver door
Old 01-06-2008, 10:21 AM
Snake's Avatar
Hi, I hope that someone can help me as I don't really waant to have to take this to a main dealer.
My electric windows will no longer operate from the drivers door on my 2006 Rodeo. They will operate from other doors. Even the child window lock on the drivers door no longer operates.
To be honest this happened after I had installed a new horn when I routed the wiring through the bulkhead so probably my own fault unless a big co-incidence.
I have checked ever single fuse, relay and all connections on every single connector block under the dash and can't find anything wrong.
I have also tested the supply to the back on the control switch on the drivers door and can't get a feed. Everything else on the control switch works i.e. electric mirrors and lock.
Could anyone suggest anything or point me towards a wiring diagram etc. as I've come to the end of the road with this one.
Thanks
Snake
_uacct = "UA-939292-44";
Old 02-05-2008, 07:09 PM
1TLB's Avatar
Snake, I would recommend at looking at a wiring diagram for your vehicle. You may have dislodged the wire from the connector when you installed your new horn.
gerdewae
02-19-2009 05:10 AM
the wolverine
02-08-2009 03:48 PM
mattlem
01-26-2009 11:34 AM
Middawg2
09-07-2008 08:38 PM
grog
05-28-2008 03:50 PM
Quick Reply: Rodeo Windows don’t work from driver door
