Erratic idle
It is a 90 2.6L FI manual. It idles smooth until it warms up, then it revs hi and low on stops, and when engaging clutch. Thanks and look forward hearing some ideas.
Anthony
edit... o, and have installed a new O2 sensor recently because light was on.Edited by: 90tr00per
Anthony
the light is set up to automatically come on every 90k regardless of the o2 sensors condition..... the light stayed on even after replacement didn''t it???
i would suspect an air bubble in your coolant system or a vaccum leak.... the 2.6''s DONT like vaccum leaks....
Originally Posted by DJ_Rob_E
the light is set up to automatically come on every 90k regardless of the o2 sensors condition..... the light stayed on even after replacement didn''''t it???
i would suspect an air bubble in your coolant system or a vaccum leak.... the 2.6''''s DONT like vaccum leaks....
Ok, I will check vacuum. ThanksEdited by: 90tr00per
