95 trooper manifold to Y pipes???
Old 07-29-2015, 09:27 PM
tompumped's Avatar
Default 95 trooper manifold to Y pipes???
I am being given a trooper and i'm not going to take it after working on it today and then coming home and finding out the pipes to the manifolds are discountinued. It's an a/t 1995 3.2 sohc. I welded the one pipe for now, but i'm not going to replace the y pipe and not the y to manifold pipes.
It's bad enough there's a hole in the frame by the rear hitch bolt location on the d/s. I can not believe isuzu managed to get away with this ****. The body is mint but the frame is rotted it has 120k and a frame as bad as the rodeo and tacomas i've seen. Maybe not as bad as the tacomas, but wtf?
If I could at least get the pipes id just drive it into the ground. It's a nice looking vehicle too bad they chose the wrong frame manufacturer.
Old 07-29-2015, 11:21 PM
tompumped's Avatar
Does anyone know where to get flanges? What diameter is the pipe and whats the bolt spacing? Thank you
Old 07-29-2015, 11:24 PM
tompumped's Avatar
I misread macs has it.
http://www.macautoparts.net/Exhaust-5814/3013332-95-Isuzu-Trooper-Engine/ProductInfo.aspx
Old 08-06-2015, 04:41 AM
Try checking Auto Parts Warehouse.
JBMoody
03-06-2013 10:07 PM
some1luvsme
10-14-2009 12:29 PM
Puna
07-09-2008 01:18 AM
hitman440
03-09-2008 10:09 AM
Wiseguy
04-14-2006 07:39 AM
Quick Reply: 95 trooper manifold to Y pipes???
