Camshaft position sensor problem
Old 09-17-2015, 03:17 PM
kyman1's Avatar
Default Camshaft position sensor problem
My 1998 Amigo was having acceleration problems so I took it to an auto parts store and had them read the obd2 code. It said it was the camshaft position sensor. So I ordered 1 and put it in. It short circuited when I turned it on. I thought maybe the part was bad so I returned it and got a new one and the same thing happened. the guy said it might be a grounding problem so I looked in the engine compartment to see if there was a loose ground. I found 2 wires. 1 black wire with a loop on the other end not connected on the passenger side fender. And a second braided wire connected on one end to the drivers side fender. both have the other ends just hanging there. I can't seem to find what they should be connected too. I have pics of both if anyone can tell me what to attach them too or if they are just optional.[IMG][/IMG] Name:  amigofender2_zpsubsw6nq1.jpg
Old 09-17-2015, 03:19 PM
kyman1's Avatar
First pic hard to see braided wire. This is on drivers side. My finger shows where it is screwed to fender
Old 04-03-2016, 11:48 AM
Ryan Mueller's Avatar
that can go literally anywhere on the block mine was on an exhaust manifold stud (not recommended they break)
ashraf
12-20-2010 08:44 AM
maintenancerus
07-14-2010 07:45 AM
maccmill
07-07-2010 10:07 AM
Quisqueya
02-07-2009 12:28 PM
2001 r_oDeo
12-31-2005 03:26 PM
Quick Reply: Camshaft position sensor problem
